98 Blazer Misfire
Old Aug 4, 2015 | 05:49 PM
theblaze1's Avatar
theblaze1 is on a distinguished road
Default 98 Blazer Misfire
Hi everyone, to start I have a 98 Chevy Blazer with 195k miles but only 50k miles on the engine and transmission. I've been having a misfire problem for the last 9 months or so, or at least 9 months where it's been bad enough that it's easily noticeable. It will misfire during acceleration around 2k rpm and is usually worst in first gear, also will misfire on highway (mainly over 65). If I accelerate very fast the problem seems to get better but sometimes will still buck a little when about to shift under high acceleration. Usually wont shift into overdrive when missing and lately I've been getting the check engine light to flash on the highway its missing so bad. Problem seems to be getting steadily worse. It's only missing in cylinders 3,4,5 when it is missing, what the misfires per each cylinder usually look like below.
Cylinder 1: 20
Cylinder 2: 20
Cylinder 3: 5000
Cylinder 4: 60000
Cylinder 5: 10000
Cylinder 6: 20
Those are approximate as I don't remember exactly the last time I scanned it. That pattern is what always shows up, always a ton in 4 and less in 5 and even less in 3 and almost none in the rest.
From what I've noticed is that it runs worse the colder the air is outside, not so much the engine temp, though when it's fully warmed up it will drive slightly better. Whats odd is when its hot out (95 deg) it will run perfect and you wouldn't even know it has a problem, but when its cooler (65 deg and lower) it drives pretty bad.
Only codes it sets are P300 (Random misfire), P304 (Misfire in 4) and P0135 (bad O2). I've already replaced that O2 it's referring to so I'm assuming that’s coming up since the misfires though. Alright now I'll list everything I've done,
New Cap and rotor, wires and plugs (with ACDelco)
O2 sensor (bank 1 #1 I think it was)
Camshaft Position sensor
Injectors
Fuel filter
Checked for vacuum leak
Ignition Coil
Compression test (Compression was solid)
EGR valve
Also checked throttle position sensor and intake air sensor with a multimeter and they seemed like they operated correctly. Also looked at the MAF and it looked VERY clean but never tested it.
Also when I checked the compression I must of pulled/pushed the wire off/on the ignition coil as it started to have a spark jump across the ignition coil. Whats odd though is I plugged it into my uncle's scanner and was watching the misfires as it was running (this was all before I realized that the spark was there) they were all showing up in 3 and 4 and sometimes 5. So there is something that's causing a very hard time for the spark to ignite in those specific cylinders.
If anyone has actually read this all and made it to the bottom then thank you!!! I've been pulling my hair out trying to figure this out and it makes me more mad I haven’t fixed it yet then it running bad. If you know anything about these 4.3l engines and a similar situation to mine please let me know, it would be GREATLY appreciated.
Thanks to all!
Hopefully I didn't miss anything, have any questions just ask.
Old Aug 4, 2015 | 08:15 PM
Ricco's Avatar
Ricco is on a distinguished road
If the compression is solid look for spark plug wire being in the wrong spark plug. Also I'm not sure if you have 2 cats as my blazer it's a 95 and have only one. Ur problem is to the one side of engine, so perhaps there is a second knock sensor (some cars have 2 one on each side of engine). I'm new to this engines and haven't got much experience with them yet
Old Aug 5, 2015 | 04:01 PM
theblaze1's Avatar
Thanks for the response.
The spark plug wires are connected correctly to the right spark plugs, trust me I've checked and pulled wires to check a couple of times. Secondly it's missing in 3,4 and 5 so it's not all on one side. I'm not 100 percent sure but I think there are 2 cats on it. And lastly I have absolutely no idea about the knock sensors, how do you know if they are bad?????
Old Aug 5, 2015 | 04:38 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Did you find anything helpful here?
https://blazerforum.com/forum/2nd-ge...ng-post-13501/
Old Aug 6, 2015 | 06:24 AM
Ricco's Avatar
I did a quick research and it seems like an oscilloscope is your best bet to check it. As the engine knocks it advances or retard the spark timing, With this said perhaps you can plug in your scanner and see if your engine timing is moving as you accelerate your truck. Hope this helps a bit
rrk03300
Nov 15, 2012 10:29 PM
jmatt07
Dec 18, 2009 09:48 AM
cdonofrio13
Aug 10, 2008 07:06 AM
Mustgofaster
Jan 11, 2008 10:36 PM
gus
Apr 4, 2007 07:42 PM
