98 jimmy stalling wont restart till cool
RE: 98 jimmy stalling wont restart till cool
look for a thread called 4x4 no worky in the do-it-yourself section.
it will cover teh vacuum lines pretty well. if you still have questions, post up.
vacuum leaks will cause performance problems.
ORIGINAL: swartlkk
NO, you do not need to do anything with the PCM when you replace the ICM.
As far as the wiring, I have seen wiring splice jobs cause excessive resistance and a no start condition. It is possible that the shop that did the replacement just didn't seal up the wiring properly. I find that the 3M shrink wrap butt connectors work great in applications such as these. They have a heat activated glue inside that completely seals the connection as well as strain relieves the splice.
Hope this helps!
Hope this helps!
Thanks,
Craig
Walmart of all places! I was just as shocked when I found them there. That is where I buy them from now. These butt connectors are the best you can buy retail IMO.
THOMA8d
08-13-2010 09:03 PM
chazsblackbravada
06-28-2010 11:31 PM
Ugly_Monkey
04-20-2009 10:40 PM
