98 jimmy stalling wont restart till cool
Old May 1, 2008 | 07:37 PM
Hanr3's Avatar
Default RE: 98 jimmy stalling wont restart till cool
look for a thread called 4x4 no worky in the do-it-yourself section.
it will cover teh vacuum lines pretty well. if you still have questions, post up.
vacuum leaks will cause performance problems.
Old May 1, 2008 | 11:21 PM
4x4blazerguy's Avatar
ORIGINAL: swartlkk
NO, you do not need to do anything with the PCM when you replace the ICM.
As far as the wiring, I have seen wiring splice jobs cause excessive resistance and a no start condition. It is possible that the shop that did the replacement just didn't seal up the wiring properly. I find that the 3M shrink wrap butt connectors work great in applications such as these. They have a heat activated glue inside that completely seals the connection as well as strain relieves the splice.
Hope this helps!
Where do you buy the 3M shrink wrap butt connectors?? I don't believe I have ever seen them. I use shrunk tubing but a shrink wrap connector would be real cool.
Thanks,
Craig
Old May 2, 2008 | 09:38 AM
Walmart of all places! I was just as shocked when I found them there. That is where I buy them from now. These butt connectors are the best you can buy retail IMO.
ohsofly
Sep 7, 2010 02:55 PM
THOMA8d
Aug 13, 2010 09:03 PM
chazsblackbravada
Jun 28, 2010 11:31 PM
Son of Odin
May 4, 2009 08:39 PM
Ugly_Monkey
Apr 20, 2009 10:40 PM
