98 zr2 blazer sloppy idle
Old Aug 21, 2014 | 10:26 PM
berndttyler98's Avatar
berndttyler98 is on a distinguished road
Angry 98 zr2 blazer sloppy idle
I have a 98 zr2 blazer that I started up last week and it had a super sloppy idle. It used to pur like a kitten. I cleaned the throttle body and replaced the mass airflow sensor and it still didn't help at all. What it does is idles supr r low at like 400rpm then itll start to die and catch back up with its self and shake really bad. I was mess in with it yesterday and found out that if I unplug the ac pump then it idles perfect, but if I plug it back in, then it goes right back to being sloppy again even if my ac is off. Could it be tge solenoid that tells it to idle up when the ac kicks on? If it is tgen couk someone please tell me the name of that solenoid. Also it needs an alternator but it needed one before this happened. I need help bad. Its my daily driver to school and work and i just want it fixed. Thanks
djschmidty
Nov 21, 2009 11:52 AM
88blackzcand95blazer
Dec 19, 2008 08:13 PM
BlazerChops
May 13, 2008 03:02 PM
timetoblaze
Engine & Internal
Oct 18, 2004 02:22 PM
