99 Blazer with odd problems...
Old Jul 31, 2013 | 11:23 AM
Wolvezbane's Avatar
Wolvezbane is on a distinguished road
--UPDATE--
Just got a call from the machine shop.
After examining the heads the following was found.
NO CRACKS!
Valves pitted badly.
Cylinder 4 exhaust valve bent from striking piston after rocker broke.
Solution,
Replace all valves.
Replace valve seats with new spiral seats.
Replace springs.
Grand total,
$375.00 total for both heads.
Outcome: HAPPY!
Old Aug 5, 2013 | 11:23 AM
Wolvezbane's Avatar
Well problem solved.... This is what caused my headaches... Along with the stupid rocker and bad spider.
I think the injector may have caused all this damage.
Now I have to wait a week for my new roller rockers to come in!
Old Sep 16, 2013 | 06:52 AM
Wolvezbane's Avatar
Default Update!!!!!!!!!!!!!!!!!!!
Ok, so after 2 months of being down she is alive, New spider, new coil, new plugs new wires, "new" entire top end, new cats, and new O2 sensors!
New PROBLEM!!!!!!!!!!! An outright blatant misfire of cylinder 2!!!!!!!!
I am now at my wits end.... Anyone who can help... please help! I am going insane here!
Old Sep 16, 2013 | 12:01 PM
Wolvezbane's Avatar
ok new symptom... popping through the upper air intake aka plenum.....
I may have gotten ahold of a bad spider injector?
Old Sep 19, 2013 | 11:24 AM
Wolvezbane's Avatar
Ok problem solved! Bad injector at cyl 2
Now why am I running lean?
LT FT Bank 1 and 2 at idle well within the -10% to +10%
Under load = 14% + and up on both banks.
O2 bank 1 = .1-.4 volts O2 bank 2 = .1-.4 volts....
Will be checking vacuum for leaks tonight. Do not think it will do any good as I have replaced all Vacuum lines when top end of engine was being rebuilt.
Old Sep 25, 2013 | 11:19 AM
Wolvezbane's Avatar
Default It finally lives!
Finally after nearly 3 months!
It is alive!
Went from 12 MPG to 16 MPG...
Now it passes everything on the road.... well except the gas stations....
Now if only I would be able to tweak it to 18-20 MPG!
Old Oct 3, 2013 | 01:41 PM
CPLSeraphim's Avatar
CPLSeraphim is on a distinguished road
Man you hae had quite a run to get this thing on the road again. I have mine sitting at the moment. Havent driven it a mile since I got it. 2 codes on it. Random misfire and tranny slipping. Hopefully it won't be as drawn out as yours, but at least I know where to look if the tune up doesn't work. I'm glad to hear you are on the road again. Congrats.
Old Oct 9, 2013 | 05:24 AM
specialty8's Avatar
specialty8 is on a distinguished road
my 02 envoy did the same thing. the plastic filler tube cracked at the tank and had to replace the tank. when it rains it pours!
boondox blazer
Feb 14, 2013 11:20 AM
blbikerood
Jan 30, 2010 12:13 PM
jsmz
Dec 22, 2009 09:10 PM
Raanerud
May 6, 2009 06:49 AM
Z Fury
Jul 14, 2008 08:36 AM
