99 blazer starting problems
Hi, I purchased a '99 Blazer last year ans since then have replaced the transmission, fuel pump, distributor cap, starter, battery, spark plugs, and just today the ignition coil. I have had it running although recently it hasn't been, the reason I replaced the ignition coil today is it won't start. It starter cranks, the fuel pump is good, but it won't fire at all. When I shut the key off it diesels for a sec. but that's it. Any suggestions.
Have you pulled out a plug and checked to see if there's a good spark when you crank?
I just tried removing a plug and seeing if it sparks, which it doesn't, I'm going to take the battery in to get a new one tomorrow because I think it might be causing some issues. If you have any other thoughts please let me know.
You said you changed the coil & distributor cap. Stupid question... did you replace the rotor too?
Are all the wires and connectors in place? Are the spark plug wires good?
cgrett
Nov 15, 2010 09:08 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Dean S
Jan 30, 2006 02:51 AM
