99 blazer starting problems
Old Jan 25, 2010 | 09:40 PM
Bootyjones's Avatar
Bootyjones is on a distinguished road
Default 99 blazer starting problems
Hi, I purchased a '99 Blazer last year ans since then have replaced the transmission, fuel pump, distributor cap, starter, battery, spark plugs, and just today the ignition coil. I have had it running although recently it hasn't been, the reason I replaced the ignition coil today is it won't start. It starter cranks, the fuel pump is good, but it won't fire at all. When I shut the key off it diesels for a sec. but that's it. Any suggestions.
Old Jan 25, 2010 | 11:33 PM
sparky672's Avatar
sparky672 is on a distinguished road
Back to basics, right? Fuel, Spark, Compression, etc...
Have you pulled out a plug and checked to see if there's a good spark when you crank?
Old Jan 26, 2010 | 10:39 PM
Bootyjones's Avatar
Default reply to sparky
I just tried removing a plug and seeing if it sparks, which it doesn't, I'm going to take the battery in to get a new one tomorrow because I think it might be causing some issues. If you have any other thoughts please let me know.
Old Jan 27, 2010 | 09:36 AM
sparky672's Avatar
If the battery is strong enough to crank the engine over then you should be getting a spark.
You said you changed the coil & distributor cap. Stupid question... did you replace the rotor too?
Are all the wires and connectors in place? Are the spark plug wires good?
Old Jan 27, 2010 | 10:31 AM
hubert hefner's Avatar
hubert hefner is on a distinguished road
you might check the ignition module also.
Old Jan 28, 2010 | 02:32 AM
dsrp's Avatar
dsrp is on a distinguished road
check pick up coil and wires if you ave fire from the pick up coil your distributor might be the problem,
Old Jan 29, 2010 | 08:58 AM
Bootyjones's Avatar
Default Its alive
So after replacing the battery it starts without fail. I wasn't sure if that would fix it because I bought a battery for it last year but it works. Thanks for your tips.
Old Feb 9, 2010 | 06:09 PM
Bootyjones's Avatar
Default More issues
So now my Blazer sometimes stalls after idling for a few minutes, then afterward won't start. Any thoughts?
cgrett
Nov 15, 2010 09:08 PM
upblazer95
Apr 4, 2009 08:27 PM
Sprocket
Mar 20, 2008 09:39 PM
Chev it or leave it
Nov 22, 2006 10:08 AM
Dean S
Jan 30, 2006 02:51 AM
