99 Blazer ticking noise in gear
Old May 2, 2010 | 11:32 PM
bammontana's Avatar
bammontana has a little shameless behavior in the past
Default 99 Blazer ticking noise in gear
Well its that time of the year where I dust off the truck and get her ready for the beach. Have been driving her around lately, and I have a heard a knocking sound under hard acceleration. Take the foot off the pedal and return to normal acceleration, it goes away. Note, when in park or neutral I do not hear this sound no matter the RPM.
Tonight on our way back from a store we heard a ticking now, happens at a lower RPM then then the knocking sound but goes away after taking the foot off the pedal and giving her a small amount of gas. Again, this sound as well is not apparent in park or neutral.
I looked under the truck, and I noticed the cross member near the tranny and right cat, it looked like it was soaked with something. I noticed on the pan bolts of the tranny there is fluid there as well.
I looked at the stick, and it was bone dry! Now, the only thing is I am parked on an incline, so that might be throwing it off, but still the incline is not that much for show the stick dry. Even warm after driving I expect to see something.
Thing is the truck shifts smooth, have not noticed any slippage or CELs. First things first tomorrow I am dropping the pan to see if there is any metal shavings in it. I have not been driving the truck as a daily so hopefully I have not done to much damage.
I need to check the fluid tomorrow on a more level ground, but this is uh.. wow.
Any thoughts on this?
Old May 3, 2010 | 07:44 AM
Do you notice any excessive engine movement when in reverse or forward while holding the brake and giving it some throttle?
Old May 3, 2010 | 10:28 PM
bammontana's Avatar
I am going to have to check that tomorrow - guessing that would be the mounts?
Old May 3, 2010 | 10:57 PM
Yeah, if it is moving a lot, the mounts would be bad.
Old May 4, 2010 | 05:28 AM
brett robinson's Avatar
brett robinson is on a distinguished road
yea my mounts are horrible anyone know were i can get some cheap????
Old May 4, 2010 | 06:32 AM
A parts store? They aren't that expensive. But lets not get into that here as it may drive this thread off topic if the mounts are not the cause of the issue in this thread.
Old May 9, 2010 | 12:53 PM
bammontana's Avatar
Kyle I think I narrowed it down - bad rear u-joint. I took apart the rear rotor because I narrowed the noise to that section. Well at least I thought, until it popped into my head, that noise is familiar. Sure enough, I just took the drive shaft off to find the rear u-joint pretty much frozen, very hard to move.
Time to replace.
marlboro124
20
Oct 6, 2011 11:55 AM
Killah_K
Jun 21, 2010 04:35 PM
mmagana
Jan 9, 2010 08:18 PM
breakyadown89
Oct 17, 2009 11:45 PM
pmezo
May 16, 2009 12:18 AM
