99 S10 Blazer Starting problem
Old Oct 23, 2010 | 04:49 PM
mthomasc's Avatar
mthomasc is on a distinguished road
Default 99 S10 Blazer Starting problem
I have a 99 Blazer with a 4.3 and remote start. For the past month I've had a problem........Turn the ignition and get nothing but dash lights. Starter isn't cranking over. I've replaced the starter and magically the truck was working again for about a week or week and a half, at most. Same issue happened again and I replaced the starter again. this time the problem didn't go away; turn the key and dash lights only. The starter was able to be shorted and it did start. Turned off the vehicle and it was hesitant to start again, but did. now I'm back to the same problem and have no clue as to what the issue is. please help, can't afford to have this looked at.
Old Oct 23, 2010 | 04:51 PM
Does it start via remote? If so, your ignition switch is likely at fault. If not, you could have a problem with the trigger wire from the ignition switch to the starter.
Old Oct 23, 2010 | 04:54 PM
mthomasc's Avatar
It never did start with the remote start since I purchased the vehicle. How do I fix the issue.... A big thanks to you for the reply.
Old Oct 23, 2010 | 05:04 PM
On the remote start, good luck.
As far as the no start with the key, I would probe the wire at the starter to see if it is getting voltage properly. If not, move under the dash to the wiring from the ignition switch (large connector directly under the column). Check the link in my signature for a wiring diagram.
Old Oct 23, 2010 | 05:53 PM
mthomasc's Avatar
I will check this and re post....Thank you so much!!!!!
NightSwan
23
Dec 26, 2014 02:06 PM
bcny168
Oct 5, 2012 11:22 AM
v8vega
Jul 4, 2011 09:55 AM
anthonyspain
Feb 12, 2010 04:23 PM
Stephen1966
Jun 22, 2008 06:16 PM
