Abnormal gear switching.
Old Dec 28, 2012 | 09:09 PM
chadmd80's Avatar
chadmd80 is on a distinguished road
Default Abnormal gear switching.
Bear with me as I try to explain what is going on. Keep in mind that this doesnt happen all the time. Usually when the truck is cold but not always then.. What is happening is when I first pull out it seem to totally skip 1st gear and go into second which creates a total loss of power. It also will not kick into overdrive when it does this so running 65mh the rpms are sitting above 2.5. Also when this happens when you are slower the transmission will jump back and forth from higher to lower gears causing an almost stuttering effect. The tach will go up and down as it does it. Their are two things that seem to fix it. 1 is if I drive for a bit at around 60mph then it will suddenly kick into overdrive and then things will be fine and it will cycle through the gears normally and the second thing is to start out from a standstill pretty fast so that it runs through first gear pretty tight. that works as well.
Just trying to figure out what might be causing this issue. Hope I explained it well enough so that you guys understand what it is doing. Thanks for any comments on what it may be
Chad
98 Blazer ZR2
Old Dec 28, 2012 | 09:18 PM
Have you changed the transmission fluid & filter lately?
(Should be done every 36K miles)
Does the SES light work?
Does it come on or flash while driving?
Are there any DTC's in memory?
If so, what are they and what order are they in?
Old Dec 29, 2012 | 12:53 AM
chadmd80's Avatar
The SES light does work and is not currently on. I will get the Transmission Fluid and Filter Changed tomorrow and swing by AutoZone and see if they still pull Codes. If they do I will report back with what I find.. And could it be an ECM problem?
Last edited by chadmd80; Dec 29, 2012 at 01:02 AM. Reason: Thought of another question
Old Dec 29, 2012 | 07:52 AM
Without any DTC's in memory or the SES light on, it's doubtful the PCM is causing the problem.
Old Dec 30, 2012 | 10:27 PM
Jimmy_Blazer's Avatar
Jimmy_Blazer is on a distinguished road
I have this same problem, though mine doesnt skip 1st gear, it shifts normally but wont go into OD until after a few miles, I don't know if the transmission just has to warm up or something, the fluids are fine. Other times it wont kick into OD at all and I will be on the highway running 2.5k+ rpms
Old Jan 1, 2013 | 01:59 AM
chadmd80's Avatar
I had the transmission flushed and have only driven it once since then. It shifted fine and didnt have any of the former symptoms. I will keep an eye on it and give a better update in a few days. Thanks for the suggestions guys. Its really appreciated.
Old Jan 1, 2013 | 10:32 AM
Transmission flushed, but did they replace the filter after the flush?
nktidwel
Jul 10, 2020 11:08 PM
jayfire
Oct 24, 2009 12:12 PM
14Blazer88
Feb 6, 2009 11:54 AM
2001blazer
Nov 17, 2006 01:37 AM
DavidBoone
Jun 21, 2006 06:41 PM
