Abs and emergency brake lights
Old Jul 28, 2019 | 12:11 PM
Skinnykenny's Avatar
Skinnykenny is on a distinguished road
Default Abs and emergency brake lights
I have a 2002 blazer. Every so often the abs and the emergency brake lights come on at the same time. I put it on the scanner but it doesn't show any codes. I was wondering if anyone else has had this issue and if they found out what the problem was.
Old Jul 28, 2019 | 04:02 PM
bigheartedchilly's Avatar
bigheartedchilly is on a distinguished road
That's a possible ABS module failure which can be "repaired". You can check this thread for a bit of info, or do a search on the forum for further ideas/solutions, loads of it on here regarding the issue.
Old Jul 29, 2019 | 04:10 AM
Thanks I will.
Old Jul 29, 2019 | 07:32 AM
I had one do the same thing on a different blazer I had, pulled the abs computer unit and fixed it up like the video shows in the link. Worked perfect afterwords... good luck
BlazerFitz
Sep 8, 2018 05:56 PM
Raman04
Jun 5, 2017 05:59 PM
Hank
Nov 24, 2013 07:07 AM
muddchevy
Aug 2, 2013 07:13 PM
HoopLa
Dec 7, 2012 09:13 AM
