Abs type
Old Dec 27, 2017 | 01:58 PM
Snap-Off's Avatar
Snap-Off is on a distinguished road
On the 95 , it's commonly referred to as OBD 1 1\2 ...It has the OBDII style connector, so the scanner will fit , just won't send any info..
Best method to get codes from a 94 and 95, besides the TECH 1 and Tech 2 is to use the paperclip trick and count the SES\CEL light flashes.
Old Dec 27, 2017 | 02:03 PM
Snap-Off's Avatar
This references a 95. the pins to jump will be different on a 94.
https://blazerforum.com/forum/lighti...scanner-95933/
Old Dec 27, 2017 | 04:46 PM
Rick Espinoza's Avatar
Rick Espinoza is on a distinguished road
would that be pins 4 & 5 or 4 & 6? Right now I have the ABS light on only, is there a paperclip trick for that too or will the paperclip for the check engine light flashes tell me the trouble codes for the ABS too?
Old Dec 27, 2017 | 04:56 PM
Lefet's Avatar
Lefet is on a distinguished road
What is the paperclip trick and what are the SES\CEL light flashes?
Old Dec 27, 2017 | 05:41 PM
Snap-Off's Avatar
@ Rick , that should be Pins 5 + 6:
_______________________
\ X X X 4 5 6 X X /
`\9 X X 12 X X X 16/
Not sure if this will pull ABS codes or not.
@ Lefet: https://blazerforum.com/forum/1st-ge...-s-10-a-88639/
It should be the top right 2 PINs on the 94. Insert paperclip into top right 2 pins , then KOEO . Don't actually start the car.
Count the SES flashes(SES light on the dash) , pause , then count second set of flashes, and you'll have your code..
OBD1 codes: https://repairpal.com/gm-obd-I-code-chart
Here's another link RE this: https://www.gmforum.com/obd-i-troubl...p-test-306836/
Old Dec 27, 2017 | 07:37 PM
Lefet's Avatar
@jones531@bellsouth.net:
Thank you much, appreciate the link!
Old Dec 28, 2017 | 10:42 AM
Do you know if Autozone, Oriely or Pep boys sell a scanner that works?
Old Dec 28, 2017 | 11:52 AM
Snap-Off's Avatar
Anything in that year in a reasonable price range really won't be a scanner so to speak, just a code puller. Amazon does sell the GM Tech II for around $350... Then there are some Snapon scanners like the Solus or Modis that should work.
Old Dec 28, 2017 | 12:30 PM
Snap-Off's Avatar
Here's a less expensive option that I found:
Amazon Amazon
Old Dec 28, 2017 | 02:54 PM
Lefet's Avatar
Will this work?
https://www.ebay.com/itm/Bosch-1300-....c100011.m1850
(I'm not too good at re-posting links.)
