Why on my 1995 GMC Jimmy do I not get any communication or check light to my scanner
Old Dec 16, 2017 | 11:21 PM
Brian Mealhouse's Avatar
Brian Mealhouse is on a distinguished road
Default Why on my 1995 GMC Jimmy do I not get any communication or check light to my scanner
I just want to know why hi my 1995 GMC Jimmy can I plug in my scan tool and I've got power to it but it's not communicating it is a 16 can it's an OBD2 and I haven't had an engine check light on for quite some time it won't even come on when it is key to the on position
Old Dec 16, 2017 | 11:59 PM
'93BLZR's Avatar
'93BLZR is on a distinguished road
Your ECM/PCM could be bad
Old Dec 19, 2017 | 06:58 AM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
it is a 16 pin it's an OBD2
Not on a 95 S-series. It may have a 16 pin connector, but it's still OBD1. You either need a 95 capable scanner. There a few out there including Tech2 and older AutoXray. Or do the old paperclip count the codes routine. Difference is that since it has the 16 pin diagnostic port you need to jumper 5 and 6 to make the light blink. You probably have a burned out SES bulb since it doesn't light with KOEO.
Found this when I double checked the pins to jumper on another forum.
I found a special note relating to 1995 GM vehicles. The move to OBD-II standardization started in 1994, GM started phasing it in during 1995. However, those 1995 vehicles came in different flavors depending on the vehicle and what part of 1995 it was manufactured.
There are at least groups of 1995 vehicles which have a non-standard 16-pin connector.
The first group of vehicles still contain an ECM, rather than a PCM, and thus still report codes via flashing the MIL/SES light. The 16-pin connector is not a DTC connector, but is rather a modified ALDL connector. (The 1995 S-10 is the example used in the manual.) These vehicles are NOT OBD-II complient and will not work with OBD-II scanners.
The pin out of the 16-pin connector for these vehicles looks something like this:
_______________________
\ X X X 4 5 6 X X /
`\9 X X 12 X X X 16/
Where: X denotes pins that are unused.
Short 5 (ground) and 6 (test) to recieve ECM error codes via the SES indicator.
The IMPORTANT thing to know about this group of vehicles, is that you can still get the old style error codes from a blinking Service Engine Soon light. To do so, you short pins 5 and 6 on the above diagram.
Another alternative I found doing a search on an F-body forum is to jumper the 1995 16 pin connector to an OBD1 scanner using pins 5 and 9..
Old May 15, 2021 | 11:41 AM
1995 Aggravation's Avatar
1995 Aggravation is on a distinguished road
Just got my Actron Elite AutoScanner CP9690, and it does indeed work with my 1995 GMC jimmy.
Reads codes and shows real time engine data.
Old May 15, 2021 | 11:56 AM
As a point of clarification about the CP9690 and my Jimmy, other scanners with the OBD II connector (specifically the INNOVA 3170RS, and an older Actron) would not link or show any information.
So, I believe I have an OBD I computer, but no pin 6 on the port for the (pin 5 and 6) jumper wire method that would show flashes to count for trouble codes.
spnzz6
Aug 1, 2019 06:40 AM
mlk1950
Jan 26, 2015 01:36 PM
Zach8846
Mar 17, 2014 04:35 AM
ladyharley
Jan 14, 2011 03:04 PM
Taymacjack
Apr 17, 2009 05:05 PM
