Abs type
#21
Apparantly it includes the GM OBDI cable:
https://www.boschdiagnostics.com/diy...bosch-obd-1300
So it should...
So it should...
#22
I'm actually liking the one you found a little better. It doesn't appear the Bosch will actually work on our vehicles. At their site, you can put in your specific vehicle to see if it will work and it doesn't go back as far as 1994. I have other vehicles and do work on a lot of my family's vehicles so it won't be a waste of money if it's a decent unit.
#23
@ Rick , that should be Pins 5 + 6:
_______________________
\ X X X 4 5 6 X X /
`\9 X X 12 X X X 16/
Not sure if this will pull ABS codes or not.
@ Lefet: https://blazerforum.com/forum/1st-ge...-s-10-a-88639/
It should be the top right 2 PINs on the 94. Insert paperclip into top right 2 pins , then KOEO . Don't actually start the car.
Count the SES flashes(SES light on the dash) , pause , then count second set of flashes, and you'll have your code..
OBD1 codes: https://repairpal.com/gm-obd-I-code-chart
Here's another link RE this: https://www.gmforum.com/obd-i-troubl...p-test-306836/
\ X X X 4 5 6 X X /
96jimmyslt4x4
07-18-2011 10:08 PM
Katmandu
06-27-2011 07:00 AM
iamchevyman5
02-28-2011 04:35 PM
davidsv8mustang
12-08-2010 10:23 AM
stormshadow1
04-23-2009 09:46 AM
