Acetone in gas to improve mpg
Old Mar 27, 2008 | 10:16 PM
AJBert's Avatar
Default RE: Acetone in gas to improve mpg
This has been around long than the internet. There are those who swear by it and those who say it is a myth. I tried it a while back in a half ton Chevy and didn't really notice any difference. Didn't hurt anything as the truck now has close to 300K miles on it but didn't help anything either. Go ahead and try it, maybe you'll be one of the ones that swear by it.
Old Mar 27, 2008 | 11:30 PM
4x4blazerguy's Avatar
ORIGINAL: WolfPack
I did a bit of research. Acetone is not a fuel. It does not burn like a fuel. Acetone does however, have a much lower vapor pressure than gasoline, so what will happen, is that as the acetone vaporizes and explodes (Explosive concentrations of acetone are a mere 1.4% in air, where as Chevron regular unleaded is 2.4% in air), it does indeed break up the surface tension of the gasoline at the molecular level. This lets the gasoline fully combust.
So acetone does not improve preformance on it's own, it simply helps the engine acheive more complete combustion = better MPGs.
So i'm going to retract my previous statement. However, I will not be the first one on the forum to try this
You are 100% correct. I have used acetone for years. On the newer vehicles I have found an increase of about 1.5 MPG. On old school stuff like my 86 F250 4x4 460 I notice NO difference. My wife gets 24 MPG on her 93 Lumina with a 3.1 V6 with acetone. Without it she gets 22.5-23 MPG. On an 04 Trailblazer 4x4 freeway driving 70 MPH with acetone 21.5-22 MPG, without it 20-21 MPG. As for a noticable performance difference I have not seen anything that really shows that. One of the biggest things I DO NOTICE is having to change FUEL FILTERS. I drove that Trailblazer to 80,000 miles and never changed a fuel filter. The Lumina hasn't been changed in 4 years that I know of. My F250 4x4 hasn't had a filter changed in about 6 years. So it does keep the fuel system clean. Now if you have a messed up fuel system acetone will clean it but you may need to change fuel filters for awhile.
In the 1930s Acetone was used in the Indy 500 cars.
I'm giving you my experience of using acetone for over 10 years in diferent vehicles we have owned.
Old Apr 9, 2008 | 11:05 PM
fade2black2004's Avatar
fade2black2004 is an unknown quantity at this point
Myth Busters already disproved this myth
in fact i remeber it causing alot of problems
Old Apr 9, 2008 | 11:09 PM
WolfPack's Avatar
I thought on Mythbusters they ran straight acetone?
Old Apr 10, 2008 | 06:54 AM
Yeah, they did and that FOR SURE will cause problems. They didn't mix it to the appropriate levels.
Old Apr 10, 2008 | 04:34 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
also mythbusters used an older engine. i beleve it had carbs on it. acetone might work differently in fuel injected.
NATE413
Feb 11, 2015 07:20 PM
dak2007
Oct 14, 2012 09:08 PM
PubEnemy
Aug 1, 2011 08:27 AM
2002XTREME
Mar 29, 2008 08:17 AM
zachwagner
Suspension Tech
Dec 11, 2006 08:01 PM
