air pump
Old Jun 8, 2009 | 12:33 AM
silentfilmstar's Avatar
silentfilmstar is on a distinguished road
Default air pump
I would like to know what exactly an air pump/smog pump does and if I can drive 2000 miles with out one.
thank you.
Old Jun 8, 2009 | 09:47 PM
Old Jun 8, 2009 | 10:20 PM
86Blazer4x4's Avatar
86Blazer4x4 is an unknown quantity at this point
would you get any performance gains out of it? and how would i modify the PCM if i did this.
Old Jun 9, 2009 | 02:07 AM
so can i drive 2000 miles without having to worry about anything messing up?
Old Jun 9, 2009 | 03:00 AM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
AIR == air injection reaction. It is an emissions system that is supposed to boost the efficiency and life expectancy of the catalytic converter by injecting fresh air into the exhaust before the catalytic converter. To remove this system, you must have your PCM modified to remove the AIR system DTCs.
Performance gains, according to the above, NONE.
To modify the PCM, you would need to take it to a dealer that has a Tech2 programmer.
Only your cat converter. Which runs several hundred dollars and can have an effect on your O2 sensors causing your CEL to come on.
Old Jun 9, 2009 | 05:55 AM
then what would be the benefits of removing the AIR pump?
Old Jun 9, 2009 | 07:36 PM
It really comes down to what everyone asking these questions is driving...
BouncingRadical
14
Nov 27, 2015 12:30 AM
nuwave
Feb 10, 2011 01:28 PM
jojocarreno
Jul 1, 2010 07:30 PM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
