air testing a trans
Old Apr 3, 2010 | 03:42 PM
Dakota_Don's Avatar
Dakota_Don is an unknown quantity at this point
Default air testing a trans
Hello, im about to finish my 700r4 build, can this unit be airtested using the case ports as well? also when testing the clutch pack assembled into the pump only, they all worked. But i did notice a little air escaping between the pump halves near the oil port i was testing, I would assume this maybe normal.
thanks
Old Apr 4, 2010 | 02:39 PM
Hanr3's Avatar
yes you can air test the tranny before final assemble. Im not familiar enough to tell you how to do it. Should be in your ATSG manual.
Old Apr 4, 2010 | 02:49 PM
Dakota_Don's Avatar
yes it can be tested, but it requires a plate that bots inplace of the VB
BobTheBlazer
Jan 24, 2008 05:54 PM
Whutdidyousay
Oct 16, 2007 09:50 PM
fjdavid
Aug 16, 2007 07:32 AM
kerander
Apr 26, 2007 01:45 PM
dax44
Dec 26, 2006 08:39 PM
