antifreez in the oil!!!
Old Feb 22, 2009 | 10:59 AM
blazerchris's Avatar
blazerchris is an unknown quantity at this point
Default antifreez in the oil!!!
ok so there is antifreez in the oil which makes me think it is the head gasket?, what are the other possibilitys it may be besides a cracked block?, i was thinking of going to get a commpresion check?
please any thing helps, thanks ,chris
Old Feb 22, 2009 | 11:17 AM
VetteGal's Avatar
VetteGal is an unknown quantity at this point
Default RE: antifreez in the oil!!!
Crack in the block, Cylinder head gasket, Crack in the head. Actually I would try pressurizing the cooling system with a dye in it. Then remove spark plugs and see which cylinder (if any) has the dye. If the dye is present the it is either a cylinder head crack or a bad gasket. If it is just in the pan the you have a cracked block. For either the bad block of head I would get it magnifluxed to find out for sure before turning to new parts.
Hope this helps
Old Feb 22, 2009 | 12:36 PM
quik1964's Avatar
quik1964 is an unknown quantity at this point
there is a possibility that your intake manifold gasket has failed, dumping coolant where it should not go.
Old Feb 22, 2009 | 12:38 PM
VetteGal's Avatar
Yep, forgot about that one. Thanks quik
Old Feb 22, 2009 | 12:55 PM
samuknow's Avatar
samuknow is an unknown quantity at this point
ORIGINAL: quik1964
I would bet on this one. This is very common.
Old Feb 22, 2009 | 02:08 PM
ORIGINAL: samuknow
ORIGINAL: quik1964
Exactly. LIM gasket failure is VERY common.
bksowers1
Nov 27, 2008 05:36 PM
bksowers1
Nov 26, 2008 09:12 PM
todaresqSL2
Nov 10, 2008 01:47 PM
shooter2499
Feb 4, 2008 09:23 PM
KA3AX
Jan 15, 2007 01:33 AM
