Anybody know the cause of these readings?
Old Oct 18, 2017 | 04:47 AM
GreenBlazer2002's Avatar
Default Anybody know the cause of these readings?
Old Oct 18, 2017 | 08:27 AM
LesMyer's Avatar
https://blazerforum.com/forum/tech-a...agnosis-26408/
Sorry but since the vehicle is in front of you (instead of us) you will have to do some work to diagnose. They aren't codes that simply identify a bad part.
Start with the lowest code first (P0101)
Old Oct 18, 2017 | 07:46 PM
Yeah thanks for that.
Old Oct 19, 2017 | 07:47 AM
LesMyer's Avatar
Which way should I take that?
Old Oct 19, 2017 | 04:33 PM
Rusty Nuts's Avatar
I read that as a kind appreciation for your thoughts, with some frustration at his blazer, not you. Green blazer red butt. I've been on both sides of that one brothers.
Old Oct 19, 2017 | 05:55 PM
Exactly. I've done the research and it points to the cat. It's been rattling since I bought it last October, but ever since the temperature dropped to the 40s at night I've been getting the p0101 intermittently. And I have the "loss of power" syndrome as well.
I've seen the exhaust on eBay for $237 with free shipping. Seems like a good deal.
But first I should correct the cylinder 4 misfire issue, which probably contributed to the demise of the cat.
This is an 02 2dr rwd, btw. 211k.
Old Oct 20, 2017 | 07:48 AM
LesMyer's Avatar
absolutely. Replacing the cat will not fix the underlying cause of it's failure.
Old Oct 20, 2017 | 08:12 AM
I'm going to purchase the exhaust and the spider assembly and do both the following weekend after they arrive.
Any suggestions on what else may need attention while I'm working in these seldom seen areas?
Old Oct 20, 2017 | 10:25 AM
LesMyer's Avatar
I would definitely check out the reasons for P0101 and P0155 codes.
Old Oct 20, 2017 | 01:32 PM
I have 3 new o2 sensors on stanby for tje p0155.
The p0101 is a mass airflow code, and according to what I've researched on here I'm thinking it's being caused by the cat as none of the other possibilities pan out.
dave's_k5
15
Jun 14, 2012 06:04 AM
mikeyfan3
Dec 15, 2009 12:29 AM
s2009jon
Aug 30, 2009 01:49 PM
1996blazer
Dec 18, 2008 07:01 PM
ivannj
Feb 11, 2006 05:38 PM
