98 Blazer 4x4 Tranny
Old Oct 19, 2017 | 07:13 PM
Johnny Bounds's Avatar
Johnny Bounds is on a distinguished road
Default 98 Blazer 4x4 Tranny
Good evening! My 98 Blazer 4x4 will not got at all in any gear. The motor just revs. I can feel it trying but it won't go.
Old Oct 19, 2017 | 07:50 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Broken flex plate?
Old Oct 19, 2017 | 08:55 PM
Transman304's Avatar
Check fluid level and condition first. Try putting it in 4wd hi and low to see if it will move. Broken flex plate is also a possibility. Was it making any noises before it quit moving?
Old Oct 20, 2017 | 04:21 AM
It will barely move in 4 low. I don't recall any noises but I was low on fluid. It's full now but still won't go.
Old Oct 20, 2017 | 05:19 AM
Time to replace or rebuild transmission unfortunately. Good luck. Find out where you lost the fluid or you could damage the next transmission also.
Old Oct 20, 2017 | 03:23 PM
When mine went out, I was having bad shifts with engine revving between engagements. It went from seeming to work to failing in about a week of puttering around town.
I learned it was one of the clutch packs that was going out. The symptoms were exactly like when the clutch went out in my manual transmission Honda Prelude.
I burned it out by towing a 2,200 lb trailer without a transmission cooler or a temperature gauge for the transmission fluid over a period of about 7 years.
Christine
bajablazer93
Feb 28, 2016 04:15 PM
ski.dive
Feb 7, 2014 05:18 AM
RickBlazer
Jun 23, 2011 04:59 AM
reddheadnla
Apr 4, 2011 06:27 PM
ginobass
Sep 11, 2006 05:16 PM
