Bad Idle/ Cooling Problems?
Old Nov 30, 2009 | 02:01 PM
bigjon1's Avatar
bigjon1 is an unknown quantity at this point
Default Bad Idle/ Cooling Problems?
Well my check engine light came on the other day so I went to autozone to see what it was and I forgot exactly the code number was but it said the coolant temp was too low.(Which beats all I ever seen, cause the guage says it's running normal, just a little bit below 210 when fully warmed up) They said It could be low on coolant(which it wasn't), the thermostat, or the engine coolant sensor. I need to figure out where the sensor is at and what is involved in replacing it, and I was wondering if this could be the cause of the rough idle. Any help would be greatly appreciated, thanks in advance.
Old Nov 30, 2009 | 02:54 PM
The sensor for the gauge should be the same as what the PCM uses... Having the exact code (Pxxxx) would help us out a lot.
Old Nov 30, 2009 | 02:55 PM
Bberry20's Avatar
Bberry20 is on a distinguished road
here is what i got when i googled it for you.
The sensor that tells the computer the temp is located on the drivers side of the engine between the middle and back exhaust port. I checked mine and that is where it was located. hi the cts coolant temp sensor for the ecm is in front of eng in lower intake and the sender for gauge is left side between 3&5 plugs hope this helps
Hope that is what you are looking for.
Old Nov 30, 2009 | 03:18 PM
In '98, the two sensors were combined into one sensor located on the driver side cylinder head between cylinders 3&5. The vehicle in question is a 2004. I do not have information in front of me that says if they converted back to the two sensor arrangement in the mid-02 design change. But from looking at parts pages, it would appear that it is only one sensor even for the mid-02+ Vin X engines.
Old Nov 30, 2009 | 08:03 PM
bigjon1's Avatar
Hey bberry, & swartlkk, Thank yall alot, it was right where yall said it would be, between 3 and 5. I really appreciate the help!
Hunter_Zack_1994
Aug 14, 2012 08:55 AM
ZR2Winnebago
Jan 11, 2012 05:19 PM
neal
Aug 17, 2011 11:05 PM
klote82
Oct 5, 2009 06:00 PM
Nations81
Jun 14, 2006 01:31 AM
