Bad Idle/ Cooling Problems?
Well my check engine light came on the other day so I went to autozone to see what it was and I forgot exactly the code number was but it said the coolant temp was too low.(Which beats all I ever seen, cause the guage says it's running normal, just a little bit below 210 when fully warmed up) They said It could be low on coolant(which it wasn't), the thermostat, or the engine coolant sensor. I need to figure out where the sensor is at and what is involved in replacing it, and I was wondering if this could be the cause of the rough idle. Any help would be greatly appreciated, thanks in advance.
here is what i got when i googled it for you.
The sensor that tells the computer the temp is located on the drivers side of the engine between the middle and back exhaust port. I checked mine and that is where it was located. hi the cts coolant temp sensor for the ecm is in front of eng in lower intake and the sender for gauge is left side between 3&5 plugs hope this helps
Hope that is what you are looking for.
In '98, the two sensors were combined into one sensor located on the driver side cylinder head between cylinders 3&5. The vehicle in question is a 2004. I do not have information in front of me that says if they converted back to the two sensor arrangement in the mid-02 design change. But from looking at parts pages, it would appear that it is only one sensor even for the mid-02+ Vin X engines.
