Before I start tearing it down....
Old Dec 13, 2007 | 07:06 PM
96Ls4Dr's Avatar
96Ls4Dr is an unknown quantity at this point
Default Before I start tearing it down....
I have a few questions....
I know I have an intake gasket leak, could this cause antifreeze to go into the exhaust?
If not then it would be a headgasket leaking right?
I've checked the oil and tranny fluid and they are good. But I'm still loosing coolant. Nothing is leaking anywhere though. The exhaust is white all the time.
What all will I need if it is the headgasket?
Gasket set and headbolts right? A Chiltons or Haynes book.
I'm thinking about doing a good tune-up while it's getting other new things.
Distributor cap and rotor, wires and plugs, PCV and Fuel filters, what else would I need to replace or atleast check out? I bought a new t-stat and rad. cap about 2 weeks ago.
Old Dec 13, 2007 | 09:28 PM
Default RE: Before I start tearing it down....
It is possible for an intake manifold leak to get into the exhaust as the coolant passages are right next to the intake runners. However, the most common leak path is outside, followed closely by into the lifter valley (to the oil).
To diagnose a head gasket failure, a compression check should be done. By comparing the compression cylinder to cylinder, you can determine if there is a leak.
*EDIT* - How many threads do we need on this?
Old Dec 13, 2007 | 10:26 PM
96Ls4Dr's Avatar
ORIGINAL: swartlkk
Sorry, I put it in General Chat and then thought that I should have put it in the Engine section.
You could delete or move or do whatever with the one in the General section.
To do a compresion test I have to fix the intake gasket first right?
Old Dec 14, 2007 | 07:17 AM
*Thread Closed*
Please respond to the original thread on this topic by CLICKING HERE
We can always move the original thread, but you have to request it first...
shadow03
Aug 8, 2014 03:06 PM
CraigSnedeker
Apr 14, 2010 09:59 AM
96Ls4Dr
Dec 28, 2007 03:40 PM
flyinbrad
Jan 14, 2007 03:01 AM
Jimmiero
Suspension Tech
Nov 15, 2006 05:15 PM
