Suspension Tech Have a question about modifying your suspension? Ask it here.
What the highest lift before you have to start tweaking everything else?
Old Nov 1, 2006 | 07:31 AM
Jimmiero's Avatar
Jimmiero is an unknown quantity at this point
Default What the highest lift before you have to start tweaking everything else?
Ive heard that if you go any higher than a 4" suspsion lift you have to tilt your drive shaft or something of that nature is this true? I already have a 3" body lift and wanted more. I also have a set of 2" lift blocks and add a leafs sitting in garage if i buy a 4" lift kit could i just add my 2" blocks onto the 4" ones to make it 6?
Old Nov 6, 2006 | 01:27 PM
Cow Killer's Avatar
Cow Killer is an unknown quantity at this point
Default RE: What the highest lift before you have to start tweaking everything else?
for fullsize gods, go to www.ck5.com they will help u with anything fullsize.
if i remeber right, 4 inch is max on stock parts. the slipyolk in the xfer case will come out if any bigger.also the stock axles almost at thrie max for tire size. 35's are about max for a dana 44/12 bolt setup unless u are only driving it on the street, or baby it off road.
Old Nov 6, 2006 | 05:08 PM
cody32401's Avatar
cody32401 is an unknown quantity at this point
we did 10-12 inch whiplash lift on a dodge only thing we had to change was the front driveshaft had to get it custom built
(i wouldnt recommend this though)
to many shots a jager since then cant remember what all was changed out but it came with everything you needed
Old Nov 15, 2006 | 05:15 PM
LunchBox's Avatar
LunchBox is an unknown quantity at this point
ORIGINAL: Jimmiero
Not if you value your life. Very bad, bad, icky things will happen. Seriously, never stack blocks...
thiefinthenight
Aug 25, 2012 11:03 AM
mrkevinmjr
Oct 23, 2011 11:00 PM
Brian_D
May 2, 2010 06:55 PM
YOURCONNEXX
Oct 21, 2009 07:10 PM
er.rigney
Jun 4, 2009 08:28 PM
