Bench test Transmission
Old Jan 7, 2011 | 12:20 AM
AuburnBlazer's Avatar
AuburnBlazer is on a distinguished road
Default Bench test Transmission
I have a dropped 4L60 transmission and would like to know if I could bench test it or pressure check for leaks.
I am concerned that I might have nicked one of the teflon seals at the front pump.
Much appreciated and thank you.
Old Jan 7, 2011 | 06:42 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Your 4 options.
1. A local community college or transmission shop that does automatic repairs may have the equipment.
2. An engine on a test stand.
3. Pull the pump out and check. Unless it's on the input shaft. If you are that worried, just take the part out and have someone look at it.
4. Just put it in and roll the dice. It'll either work or it wont. You may have to replace some clutches, but they are fairly cheap and you'll have it out to fix the seal anyway.
Why is the transmission out in the first place? A used or reman you are putting in?
texasyankee
Aug 26, 2012 04:02 PM
siucsaluki11
Apr 11, 2011 10:37 PM
Cuchulain
Feb 3, 2009 05:20 PM
01Jimmy
Jan 3, 2009 01:33 AM
*Old_School*
Nov 21, 2007 05:00 AM
