blazer help please - 99 hard to start
Old Dec 27, 2011 | 10:31 AM
Considering that the requirement for fuel pressure is that it maintains >=50psi 10 minutes after the pump shuts off... If the pressure reaches a maximum of 55psi and is dropping as soon as the pump shuts off, I'd say you definitely have a fuel supply issue. Now time to get the necessary adapters to test at the fuel filter, isolating the pump. This is discussed in the fuel pressure test tech article. If the pressure continues to drop when testing at this location, then you either have a leaking check valve in the pump or a leaking line from the pump to the top of the fuel pump assembly. The only way to know which is to pull the pump.
Old Dec 30, 2011 | 07:27 AM
blazer0713's Avatar
blazer0713 is on a distinguished road
Alright tested at the fuel filter and still only went to 55psi and dropped 10psi in 3 minutes after key shut off so just replacing the pump and complete sending unit
Old Dec 31, 2011 | 09:20 AM
blazer0713's Avatar
Thanks swartlkk for the help and info changed fuel pump and its all better now
Jakeduece
Jan 10, 2015 05:04 PM
Kevin Gore
Dec 13, 2013 09:35 PM
dubaholic2
May 24, 2011 12:44 PM
ejxjohnson
Sep 10, 2010 08:21 PM
rogggg1020
Nov 11, 2008 08:05 AM
