Blazer rolls in park
I am new to this forum so I was wondering if someone could help me out. I got a 99 blazer. I was replacing a radio in it and after I was done I started it up and it would not move in any gear. I put it back into park and it will roll in the park position. When I put it into gear it will not engage forward or backwards. can someone help me.
You only replaced the radio and now this?? Sounds very hard to believe.
*Moved to the Engine & Transmission section* - Please choose the appropriate section based on the type of post you are intending to make.
x2 on that don't see how only putting in a radio would do that .. sounds like your shifter linkage is totally screwed
yeah i would say u screwed up the shift linkage somewhere. My buddy had the sdame problem after we rebuilt his engine, trans, t-case ect.. was out. And we had the linkage way off take a look under the blazer the linkage is on the driverside of the trans and see if it is loose while someone moves the shifter
Loxias209
Feb 11, 2009 04:54 PM
mudd4
Aug 23, 2008 05:50 PM
Sarahsmith854
Jul 19, 2007 09:03 PM
