Blazer shift problems
Old Aug 10, 2019 | 08:27 AM
crazydean's Avatar
crazydean is on a distinguished road
Default Blazer shift problems
I have a 2001 blazer, it has a 4L60E transmission. First started out reverse wouldnt work,without any repairs reverse started working, but now wont shift from low gear where it would when reverse didnt work. Any help would be greatly appreciated.
Old Aug 10, 2019 | 01:29 PM
Check the transmission fluid level. Then search for videos online that describe the typical failures for the 4L60E transmission. Those videos will help you correlate the symptoms to the failure mechanism.
Old Aug 10, 2019 | 05:01 PM
crazydean's Avatar
Default Shift problems
[QOTE=crazydean;712058]I have a 2001 blazer, it has a 4L60E transmission. First started out reverse wouldnt work,without any repairs reverse started working, but now wont shift from low gear where it would when reverse didnt work. Any help would be greatly appreciated.[/QUOTE]
Have changed fluid and filter, 1-2 shift solenoid and shift cable. Still not shifting
Kurt Phillips
Mar 15, 2014 09:21 PM
Poudre09
Nov 10, 2010 08:29 PM
Spookypaws
Dec 10, 2009 01:08 PM
mikeinwi
Feb 6, 2009 10:32 AM
felonyblazer96
Nov 6, 2007 10:41 PM
