loseing reverse gear?
Old Jan 30, 2009 | 07:26 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
Default loseing reverse gear?
the past 3 days ive started the blazer after its been sitting for the night it'll take a good 5-10mins for the reverse gear to "kick-in". once i shift from park into reverse and press the gas it acts like im in neutral, then i shifted into drive and i could feel theblazer wanting to go forward, so i shift back into reverse and nothing, the motor revs but no wheel spin or any kind of movement, but after waiting a few mins i shifted to park then to reverse again and i could feel it engage and it was back to acting normal. so is the tranny taking its last breath?? btw i also checked the tranny fluid and its a-ok.
Old Jan 31, 2009 | 01:37 PM
mikeinwi's Avatar
Default RE: loseing reverse gear?
anybody??
Old Feb 2, 2009 | 03:34 PM
Nmelick's Avatar
Nmelick is an unknown quantity at this point
I can't tell you what broke, but what I can tell you is I had the same issue with my 96 Blazer. It cost me $1100 to have the transmission rebuilt and removed and reinstalled. That included some mods that needed to be done to the transmisson.
Old Feb 3, 2009 | 03:52 PM
bamablazer57's Avatar
bamablazer57 is an unknown quantity at this point
possibly the sun gear shell. it controls reverse and the high gears... a aftermarket sun shell runs somewhat of 30 bucks just call your local tranny shops they keep 4l60e's in stock....the life expectancy of a 4l60e is 100,000 but i just replaced my sun shell and reverse sun gear and it runs like a champ.
Old Feb 4, 2009 | 05:57 PM
mikeinwi's Avatar
*update* the past few days heres its been relativly warm about 20-30 degrees and the tranny hasnt acted weird with the "warmer" weather it seems to only act up when its near or below zero is there any reason for this??
Old Feb 6, 2009 | 10:32 AM
sailcat327's Avatar
sailcat327 is an unknown quantity at this point
Having the same problem with mine. All forward gears work great all the time. It has been suggested that the filter & oil needs to be changed. I will try that and let you know.
black4x4blazer
May 23, 2010 02:48 PM
1986k5blazer
May 26, 2009 06:54 PM
neurotox
Apr 27, 2009 10:54 AM
Swblazer
Nov 14, 2007 07:43 PM
BEENDIGGIN
Feb 15, 2007 11:01 PM
