Blazer will run for 5 seconds then shut off
Old Jan 10, 2017 | 10:37 PM
Welderboy6788's Avatar
Welderboy6788 is on a distinguished road
Default Blazer will run for 5 seconds then shut off
I just bought a 2000 s10 blazer with a 4.3 I replaced the fuel pump, fuel injection spider, fuel filter, distributor, coil, rotor button, distributor cap, plugs wires, battery, alternator, tps sensor, it still won't run I've done all I know to do to it I've been researching online about the passlock II system all my symptoms are basically covered in that. The truck will crank and run fine for about 5 secs and then shut off any idea of what I can do to fix this issue? I already did a passlock system bypass n no luck now the light stays on solid but still the truck won't run any longer then 5 seconds everything is new and replaced
ShanoMac87
Nov 18, 2020 11:10 AM
SteveBessert
Aug 7, 2014 04:29 AM
reddheadnla
Apr 23, 2011 11:08 AM
midnightbluS10
Aug 7, 2009 03:07 PM
