Bluetooth scanner for transmission codes
Old Jul 19, 2016 | 02:20 PM
John925's Avatar
John925 is on a distinguished road
Originally Posted by Lesmyer
Car Gauge Pro will read any Transmission codes that you have stored. I know it will because it read mine. You need to spend some time to understand how to work the software.
I tried with Car Gauge Pro but I kept running into errors. I think the specific one from the transmission and a few others was, "negative or no response from ecu".
Old Jul 19, 2016 | 02:28 PM
LesMyer's Avatar
OK - so do you want my help with Car Gauge Pro?
Old Jul 19, 2016 | 02:29 PM
John925's Avatar
Absolutely if I can get this to at least run the tests on the transmission. That'd be great progress.
LesMyer's Avatar
DO NOT select the Transmission module. As I said before, select GM/Powertrain. There are no tests that are run by the scanner. It reads the codes stored in the computer.
Old Jul 19, 2016 | 02:31 PM
John925's Avatar
And that'll run the transmission test?
Old Jul 19, 2016 | 02:32 PM
LesMyer's Avatar
Geez - I just said there is no transmission test. It will read any stored transmission codes that are stored in the PCM.
Old Jul 19, 2016 | 02:36 PM
John925's Avatar
Oh sorry I misread
Old Jul 19, 2016 | 02:39 PM
LesMyer's Avatar
Oh sorry I misread
Select GM/Powertrain You should get to a point where it displays an address (10 on mine). Select that address and it should connect and display connected at the top of the main screen. You have to get to that point first.
Old Jul 19, 2016 | 02:43 PM
John925's Avatar
Yeah when I was given the option to select an address (10 for me as well) I had like 7 or 8 to choose from, all the same number.
Old Jul 19, 2016 | 02:44 PM
LesMyer's Avatar
After that you can go to Diagnostics and read codes (either pending codes or hard codes). Sometimes PCM has to see a code pending through multiple key cycles or failures before setting a hard code.
