Bluetooth scanner for transmission codes
Old Jul 19, 2016 | 02:44 PM
  #21
LesMyer's Avatar
are you connecting with GM Powertrain now?
Old Jul 19, 2016 | 02:53 PM
  #22
LesMyer's Avatar
I need to drive home from work in 8 minutes. I'll check this thread again when I get home. Otherwise there is always tomorrow.
Old Jul 19, 2016 | 04:14 PM
  #23
John925's Avatar
John925 is on a distinguished road
Originally Posted by Lesmyer
After that you can go to Diagnostics and read codes (either pending codes or hard codes). Sometimes PCM has to see a code pending through multiple key cycles or failures before setting a hard code.
Ok I think I got it. I got a whole bunch of codes. I did it the first time with it in the acc position, then again with it running. Thanks again for your help. Hopefully I did it right and it was accurate
Old Jul 19, 2016 | 04:18 PM
  #24
LesMyer's Avatar
If it read codes they are accurate. Now write them all down, clear the codes, and drive to see what returns. Then report!
Old Jul 19, 2016 | 04:20 PM
  #25
John925's Avatar
I've saved the reports. I just need to figure out if I can open them on my phone or have to move them to my computer
Old Jul 21, 2016 | 08:44 AM
  #26
LesMyer's Avatar
Not sure what reports you are referring to. I just display the codes in the diagnostics menu and write them down.
Old Jul 21, 2016 | 08:48 AM
  #27
John925's Avatar
Yeah I was able to save them in a file. But I got an obscene amount of codes. Would have taken forever to write down. If I can open the file, I'll upload them on here, if not, can just screenshot and upload if you want to see them.
Old Jul 22, 2016 | 07:13 AM
  #28
LesMyer's Avatar
Sure let's have a look. But also please describe exactly what you are doing and how you are generating a file. Something doesn't sound right.
RedOne
Feb 16, 2019 06:11 PM
hylander6361
Jan 1, 2016 01:29 AM
swartlkk
Mar 22, 2011 07:54 PM
carterx
Oct 25, 2009 11:06 AM
m00nwater
Oct 25, 2006 03:37 PM
