Breaks up on deceleration 01 s10 blazer 4x4 4.3
Old Jan 2, 2023 | 11:26 AM
Mrhandicapable66's Avatar
Mrhandicapable66 is on a distinguished road
Default Breaks up on deceleration 01 s10 blazer 4x4 4.3
Runs decent at idle and when you're in the throttle but as soon as you let off it starts to break up and run like crap just did a full tune up plugs wires the whole works and didn't help at all
Old Jan 3, 2023 | 10:08 AM
GeorgeLG's Avatar
  1. Do you have any codes?
  2. Do you have a scanner that can you read live data?
  3. By "breakup" do you mean the engine misfires or stumbles?
  4. Is there a difference in this behavior with just letting off the throttle vs adding braking?
  5. Has there been a recent compression test?
  6. What do the plugs look like?
A couple of things happen in decelleration. First the vacuum shoots way up so there may be a vacuum leak component. This can disrupt fuel delivery and the air/fuel mix. Live data will help look at this. Second, the engine rotates on the mounts. This can cause some vibration that you perceive as a misfire. It can also strain or short electrical connections if the mounts are worn.
Grabenfish
Jan 8, 2022 02:51 PM
A1 Handyy
Sep 25, 2020 06:33 PM
Corey Evans
Oct 2, 2018 09:27 PM
bobthehunter60
Nov 15, 2013 09:59 AM
jsabinsw
Mar 29, 2012 03:51 PM
