Broken A/C compressor?
Old May 11, 2009 | 10:49 AM
dimmuborgir6nik6's Avatar
dimmuborgir6nik6 is an unknown quantity at this point
Default Broken A/C compressor?
Ok so I've been reading a few similar threads started on this subject, but none of them seem the have the same resolution as mine.
So my A/C hasn't worked for over a year, never cared, but now that the summer's coming it'd really be nice to have it running. I checked all the hoses for leaks, nothing obvious, so now I'm coming to the compressor. How can you tell if the A/C clutch is stuck? When the clutch is spinning, is it noticable? Or is there a cover over the clutch plate? When I turn the A/C on I see nothing spinning except for the pulley on the compressor itself. Also, something new?..after running the engine cold for about a minute this morning, I turned the A/C on and noticed a high pitched squealing noise (also read this on another thread) but I just changed the belt and tension pulley a few months ago after it seized on me. The squealing continued even after turning the A/C off.. Looking at the tension pulley, the entire arm seems to be jolting as if it were lose?? It's a tight jolt though, as if it's just rocking/vibrating along with the rest of the engine vibrations. I never noticed the squealing until today, the first time I turned my broken A/C on in a while.
Old May 11, 2009 | 11:57 AM
You can manually engage the clutch by applying ground and +12V across the coil terminals. This should pull the clutch plate in against the pulley, engaging the clutch.
You can also try to turn the A/C compressor by hand. If it does not turn by hand, then the clutch will not get it going either.
Old May 11, 2009 | 12:38 PM
Yeah actually, a little before you said that I manually turned it with my hand, it seemed fine. Turned pretty easy with one hand. I also noticed a funny sound coming from either the accumulator or blower when I was turning it, kinda sounded like when you're drinking and you suck those last few drops through the straw.. real funny sound.
Old May 11, 2009 | 01:04 PM
BlazerGlenn's Avatar
BlazerGlenn is on a distinguished road
theres a switch on the right side of the compressor that ****ted out on my blazer see if you can swap it out with one of your friends to see if thats the problem its only 30 dollars I think its the low pressure somthing switch I dont really remember
Old May 11, 2009 | 01:39 PM
The low pressure switch is in the accumulator/filter/dryer assembly (silver canister) on the passenger side of the motor. The high pressure switch is in the back of the compressor.
gmcjimmy_94
Dec 30, 2010 12:37 AM
bcw757
Jul 3, 2006 08:44 PM
SniperX13
Jun 4, 2006 02:59 PM
NJEMT
Jun 1, 2006 01:40 AM
tammikm
Oct 28, 2005 12:15 AM
