Burnt rotor.
Old Jan 30, 2024 | 09:35 PM
Hess13x's Avatar
Default Burnt rotor.
Been a while since I've been on. 97 blazer. Was Driving and engine lost power and shut off. Towed it home and started doing the usual checks. Fuel pressure 60 psi key on. Then checked spark. No spark but had a tack signal, so thought it was icm. Changed that and checked for 12v on coil and icm, both good. Tried starting it and it would pop every now and then. So pulled cap.
And then the rotor
So did I find my problem?
Old Jan 30, 2024 | 09:47 PM
LesMyer's Avatar
Yes, but you should check cam sensor retard as the probable root cause of the cap/rotor failure.
Old Jan 30, 2024 | 10:48 PM
Hess13x's Avatar
Thanks Les! And yes I will check that.
Old Jan 31, 2024 | 09:36 PM
Hess13x's Avatar
Ok swapped cap n rotor still no go. Going to do more testing when its light outside and have an extra set of hands
Old Feb 1, 2024 | 11:09 AM
rockp2's Avatar
If you already haven't, you might want to remove the distro cap, check the rotor for slop and have someone turn the engine by hand to insure the rotor is is rotating.
Old Feb 5, 2024 | 10:42 PM
Hess13x's Avatar
Rotor is turning.
JavierEscalonJr
Oct 14, 2020 11:38 PM
AdsoYo
Sep 8, 2016 07:17 PM
Gearhead52
Mar 5, 2013 08:29 PM
ccrage2005@aol.com
May 12, 2011 03:44 PM
jonny22107
May 11, 2010 02:04 PM
