Bypassed Rubber Hose
Old Apr 26, 2018 | 04:55 AM
Transman304's Avatar
Originally Posted by Rusty Nuts
When you disconnect the hoses from the vacuum switch on the transfer case check the inside of those hoses for fluid as well. They're supposed to be dry.
Great tip! Not sure if his model will be equipped with that switch. That switch was known as the vampire. Suck the fluid right out of the transfer case.
Old Apr 28, 2018 | 12:04 PM
I'm a bit late with checking the OEM Manual. Correct about the hose.
This should be the vent to atmosphere of the "TRANSFER-CASE" vacuum switch.
Normally it is just the hose which has a clamp and a sponge cover. It is used as a vent.
There should definitively be no fluid coming out of there.
To make sure we do not mix up things here.
From front to back we have: ENGINE - TRANSMISSION - TRANSFER CASE
The transfer case is bolted together with the transmission and as previously stated a leaking seal could dump TRANSMISSION FLUID into the TRANSFER CASE.
The fluid for the TRANSFER CASE is also automatic transmission fluid.
Service manual says DEXRON IIE.
Old Apr 28, 2018 | 01:30 PM
Is not the fluid a special kind if you have a "4-button" transfer case?
Old Apr 30, 2018 | 02:57 AM
More recent blazes could be. The 94 is the last 1st gen. Electrically actuated Blazers have only one switch with two positions.
Manual says DEX IIE for the transfer case and DEX IIE or IIIE for the transmission on these Blazers.
86TransAm
14
Dec 13, 2011 07:46 PM
BlazeringSaddles
Nov 30, 2010 03:43 AM
chronic1
Nov 15, 2010 10:24 AM
topgunfan
Jun 8, 2009 10:14 AM
rob1621
Apr 3, 2008 08:55 PM
