Calling all transmission detectives who can help me figure out what I am doing wrong
Old Sep 10, 2023 | 02:18 PM
edgy1's Avatar
edgy1 is on a distinguished road
Default Calling all transmission detectives who can help me figure out what I am doing wrong
The details:
The drive train and chassis 2000 chevy Blazer 2 Door I used for a ****** wagon restomad had nearly 100,000 miles on it. I drove it home and everything seemed to be working well so I decided to reuse it without rebuilding it.
The transmission cooler is integrated into the new aluminum radiator that I installed in my build
In the teardown I damaged the electronics connector on the transmission, so I replaced the wiring harness on the transmission. I ended up replacing one of the solenoids as well because it was broken either before I took it apart or when I dropped the pan.
I learned later that I did not seat the electronics connector on the new harness properly in the transmission body. I was unable to get the connector vehicle wiring harness to completely seat on the transmission connector. There were a few intermittents on it, but I was anxious to shake-down the rest of the build and drive it a little, so I promised myself that I would drop the pan again soon to be able to seat the fitting properly. It would occasionally go into 'limp-home mode where it would be limited to 2 and 3 gear.
I drove it that way for about 200 miles until one day I heard a click (snap?) that sounded like a rock hitting the undercarriage and I lost all power in all gears, forward and reverse.
I was reasonably confident that it wasn't the transfercase because the wheels were locked in Park.
I had the transmission rebuilt. Replaced it this time there were no intermittents and all the gears worked perfectly, and the downshifts were perfect as well All seemed to be in order.
A couple of days after I replaced the transmission (I had driven it just 40- 50 miles) I heard a noise that I thought was a exhaust leak. (Phwit, Phwit Phwit phwit) that later developed into a more prominent noise more like squish, squish squish. The noise would go away temporarily after shifting into another gear, but would return are a few seconds. I called the rebuilder and asked him about the noises. He said that was a new one on him. He recommended that I continue to drive it- because sometimes the fittings were quite tight and it took a few miles to get them to wear-in. He said the problem would either resolve itself or the transmission would fail and I could then bring it in for replacement under warranty.
50 miles later, i had exactly the same experience driving up the very same gentle hill at 45 MPH. This time there was a louder snap, and noises like gears grinding and I lost all Power to the wheels, but the wheels still lock up in Park.
I spent four hours on Saturday dropping the transmission,( I'm getting pretty good at it. -Unfortunately)
I am looking for some thoughts from the forum if there is something basic that I have overlooked in installing the transmission that my inexperience is causing me these problems, or is it just a couple of instances of bad luck?
Some of you may remember the Maniaci brothers on the Car Talk radio program on NPR. This kind of problem would have been right up their alley, I hope there are some good detectives in the forum who might be able to identify a good course of action for. I would just as soon never have to drop the transmission again.
Old Sep 11, 2023 | 04:26 PM
edgy1's Avatar
I took the transmission back to the builder today. the TC wasn't seated properly. My best guess is right now that I did the same thing twice because last time the fluid pump connectiopn got chewed up the same way.
I am perplexed. I would have sworn that the TC was inserted as far as it could have been inserted, with the usual 3 stations (Clicks). When I installed the TC to the flex plate it was a tad more than 1/8 inch away from the flexplate. So tightening the bolts drew it slightly away from the fluid pump fitting.
Do I need to install some kind of spacers between the flexplate and TC?
I read something vague that the VINs with an X in them have different specs on the engine. Te transmission may been from another donor. Is this a possible source of my problem?
Old Sep 15, 2023 | 03:58 PM
LesMyer's Avatar
I think I have heard about some spacing of converter to flywheel differences in 4l60e's when used with different engines but that was LS V8 vs older SBC IIRC. I would go down that road of investigation. Sorry, but I don't know the particulars. Please let me know how it ends up for you. Transman304 would know..... Try PMing him (not here much anymore).
Old Sep 16, 2023 | 06:24 AM
LesMyer's Avatar
Added to post above
Old Sep 16, 2023 | 06:32 AM
LesMyer's Avatar
Transman304@gmail.com is his email address
Old Sep 16, 2023 | 07:02 AM
LesMyer's Avatar
Also some pretty good people in Transmission section
​over at Hotrodders.com forum
Jalmquist125
Aug 31, 2016 02:39 PM
Fatguy9
15
Feb 12, 2016 11:16 AM
Rumfish Mcgee
Apr 12, 2012 07:46 PM
janddcunningham
Apr 13, 2011 03:16 PM
rudnik
Feb 4, 2010 02:17 PM
