can ABS mess with the transmission?
guess its something new to everybody...... anyway.... my blazer had a wheel speed sensor wire (or abs wire??? it goes into the front wheel hub...) that was cut in half so i spliced the wire back together and there is no abs fuse in the fuse block under the hood... just wondering if either of those were messing with the trans and i fixed the wire and replaced the fuse if it would start working right the first time i drove it or if it would take a few times diving for it to start working...
A front WSS (wheel speed sensor) issue should not cause anything abnormal to happen with the transmission. Neither should an ABS issue aside from a VSS (vehicle speed sensor) issue.
As far as your repair goes, you can check the mV-AC output of the sensor with a multimeter while spinning the wheel. It should be at least 250mV-AC output.
What is your transmission doing?
will shift out of second but will not go into third. just revs and never catches... the check engine light dont work and i have only drove it twice with a good battery in it but had to take my good battery out after each time to put back in my other vehicle so i dont think the light would come on anyway untill i put a good battery in it and leave it...
intoodeep95
17
Nov 9, 2012 08:53 AM
redneck2725
Aug 11, 2009 04:01 PM
