Can I Put a 1995 4.3 Vortex in a 1999 blazer?
Old Feb 21, 2009 | 11:38 PM
AdamP's Avatar
AdamP is an unknown quantity at this point
Default Can I Put a 1995 4.3 Vortex in a 1999 blazer?
I blew up my old 4.3 for my blazer and i just bought a 1995 4.3 engine to put in it for $75 and it works. I need to know if i can put it in my 1999 blazer?
Old Feb 21, 2009 | 11:51 PM
Default RE: Can I Put a 1995 4.3 Vortex in a 1999 blazer?
Short answer, NO.
You might be able to use the short block, but from the heads on up is different.
Old Feb 22, 2009 | 01:17 AM
bandidolenny's Avatar
Up to 1995 the 4.3 was throttle body fuel injection. Starting in 1996they went to multiport fuel injection.If your heads are still good swap them, along with the entire fuel injection system, over to the 95 shortblock. Be sure to utilize all the sensors that came from your truck.
On that thought... you need to make sure that you can install the crank angle sensor onto the new (older) engine before you start wasting time and money. Anyone else have thoughts on this?
Old Feb 22, 2009 | 01:21 AM
No TBI for 95, only CPI.
Rebuilding the Chevy 262 by Doug Anderson courtesy of EngineBuilderMag.com
Take a look at that to see the changes made. It is a little light on the later SCFI motors, but should give you the gist.
Old Feb 22, 2009 | 01:37 AM
AdamP - after reading through the engine builderlink provided by Kyle I thought of Something else. I dont know if your state performs emission testing. But if they do then they might not pass your vehicle if you have an older engine than the year of your vehicle. Just something to think about.
Old Feb 22, 2009 | 08:51 AM
smdepew1976's Avatar
smdepew1976 is an unknown quantity at this point
you know i've always wondered how they'd know......in all my years of driving never once has any inspectors checked my casting numbers to see
Old Feb 22, 2009 | 09:50 AM
You have a point... How would they ever know unless they had a reason to check the casting numbers... of course the numberscould even be ground off and re-stamped but thats getting a little excessive.
Old Feb 22, 2009 | 10:20 AM
Outsydr's Avatar
Outsydr is an unknown quantity at this point
ORIGINAL: bandidolenny
Just a little clarification on that point the switch from tbi to cpi started earlier than 95 in 94 only 1% of these trucks were made with tbi the majority were cpi.
djboyzs
Oct 14, 2013 07:14 PM
chopsling
Nov 17, 2008 01:26 PM
kooz5
Mar 10, 2008 12:04 PM
redneck
Engine & Internal
Jan 22, 2008 03:23 PM
jes9999
Mar 12, 2006 01:40 AM
