can somebody tell me what I've done wrong
Today, I've decided to work a bit on my engine, I've decided to clean the Trottle body, remove the restrictor blade, clean the tps and the other sensor in the back with carb cleaner. I clean also the MAF and EGR and put everything back together. Went for a 2 min ride and everithing was working perfect. As the temperature was humid and it was raining a lot in the last week, I've decide when I got back to spray WD40 on the wires to get rid on possible water but spark plug was a bit hot so the wd40 got vaporized in smoke and I did'nt take care of it. Tonight went for a ride and engine has very hard time, don't take his gas when stomp the trottle whide open variating RPM in gear sound like the exaust is plugged, misfire a lot, I had the impression to work on 4 cylinders as i lost power
Here is my question, did you think this is the wire that I did damage while spraying wd40 when they was hot?
Can a spark plug can break out because that would be funny because they are always sprayed with cold water when it rain?
By cleaning the TPS with carb cleaner can damaged it kind of 3 hours after even if i let it dries before reinstalled it?
Or this can be simple as the computer need to be resetted with the modified trottle body?
Please Help
Please help
Please Help
Please help
Could be several problems. Did you soak the TPS, and IAC valve completly in carb cleaner? If you got the elctrical parts wet they could be damaged. Did you mess with the screw on the IAC? If so that would be a problem.
What did you clean the MAF with? Only use MAF cleaner or it could be damaged.
Use dielectic grease to protect the boots/plugs from water. Are you sure you got the boot on securly?
Didnt soak the sensors and had wait they was dried to try them.
Will also check with ELM327 and Torque app tomorrow for codes or info on the dial available.
For MAF, I've used MAF cleaner but will check tomorrow with my torque application or status but have no change on the engine plugged or unplugged
IT really seems to have no more power and is misfiring... MAF will not affect cylinder firing no?
For the plug wire, I didnt removed them just spray on it. I will unplug them and have them back in place just in case.
I've done all my work backward, reclean MAF, reclean TPS with MAF stuff, reclean IAT with MAF product reinstall the restrictor back with alum rivets then, no changes...
NO code on Torque app, all trottle, maf and Vaccuum resulta are perfect.
I disassembly the ignition wire and found out 1 of the wire was dissasembled from the metal clip that insert to spark plug. reassembled it correctly and it run perfect now. will have a longer test ride tonight but after 2 miles still OK.
thanks
thanks
Happens quite often. Those ends are fragile; cheaper the wire set, the more fragile.
brudel1
04-04-2011 12:00 PM
Thor_449
03-25-2008 08:32 PM
2klt
12-30-2006 04:24 AM
john50
04-13-2006 01:45 PM
