Can you run without the front drive shaft? 1998 4x4
Old Aug 25, 2008 | 07:51 AM
watsonracingteam's Avatar
watsonracingteam is an unknown quantity at this point
Default Can you run without the front drive shaft? 1998 4x4
My brother had removed it a month or so ago now I have some odd noise on start up coming from the front dif.
If it sits and idles I do not get it, but if I drive it right away it sounds like gears are trying to line up, they do after a few seconds then no more noise.
It would need to sit a bit, say 3 - 4 hours before it does it again.
ANY IDEAS?
Brian
Old Aug 27, 2008 | 10:14 PM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
Default RE: Can you run without the front drive shaft? 1998 4x4
mine is gone and no problesm ever??
Blade_24k
Feb 26, 2014 03:03 PM
bertrenolds
Mar 8, 2012 09:17 AM
brudel1
Apr 4, 2011 12:00 PM
jorg
Jan 28, 2011 05:02 PM
lizzj70
Jun 23, 2010 06:57 PM
