Carb cutting out
Old Aug 9, 2013 | 10:25 PM
ScottsdaleK5's Avatar
ScottsdaleK5 is on a distinguished road
Default Carb cutting out
Hey guys! I haven't posted in awhile! To update you on where I am at with my Blazer, this last winter I got rid of my 700r4(I know bad idea!) and swapped in a rebuilt th350 with shift kit! After that project I bought some Vortec heads and threw them on what I thought was a Chevy 350... It turned out to be a 400. That turned out badly! Cracked my block! Rebuilt the original motor with the Vortec heads!
That brings me to my question! Since I put the 400 in a went too carb(against my best judgement!) Well, the carb has done me just fine...until now! With my Vortec heads I had to get a Vortec intake which is for a square bore carb, I have the original Quadrajunk spread bore so I had to get a spacer.
Now every time I just barely press the throttle, say taking off from a stop, it wants to cut out. Now, I've had numerous friends tell me its getting too much fuel, but since it never happened before, I think its getting too much air, especially with the spacer! What do you guys think?! Is there a thinner adapter I can get? Do I need a different carb? Am I getting too much fuel?!
If you mash on the throttle it'll cut out for a second and then take off, takes the fun out of racing! Any help is appreciated! I'll post pics!
Thanks!
Attached Thumbnails Carb cutting out-0429131423a.jpg   Carb cutting out-0425130950a.jpg   Carb cutting out-0425130914.jpg   Carb cutting out-0503131912.jpg   Carb cutting out-0320131507.jpg
Old Aug 11, 2013 | 12:14 PM
abig84's Avatar
youre probably going to have to find someone with that exact set up to see what they did. my 400 had the original 2 bbl on it and never ran right. so finally swapped intake to a 4bbl intake, tried a quadrajet, then a edlebrak, then finally bought a new holley. even then i still had to take it to someone to have it tunned right
Brandon Smith
Dec 22, 2013 12:33 PM
justDrivin
Apr 7, 2008 06:13 PM
Blazerx85
Nov 8, 2007 06:13 PM
RCarp48
Apr 30, 2007 12:59 PM
xtreme01blzr
Oct 18, 2006 03:23 AM
