Changing Valve Cover 98 Blazer passenger side
Old Apr 5, 2013 | 10:49 PM
Ash's Blazer's Avatar
Ash's Blazer is on a distinguished road
Default Changing Valve Cover 98 Blazer passenger side
- Any advice?
- About how long?
- Will I be able to change out drivers side valve cover while I have it torn down, or is that just another 3 hours?
Thanks,
G
Old Apr 6, 2013 | 10:46 AM
s10driver's Avatar
s10driver is on a distinguished road
loosen the alternator and swing it up ( leave the one bolt still on) move all the harness out of the way and spark plug wires, remove valve cover and clean and install new seal/gasket,reverse procedure. as for the driver side, you will have to slide the power steering pump/AC compressor bracket away from the engine. or get a dremel or cut off tool and cut the back of the bracket to clear the valve cover. I've done it in less than an hour.
marksoftball
Nov 29, 2014 09:27 PM
kancop
Feb 17, 2014 08:06 AM
89Recon
Oct 22, 2011 05:50 PM
fondo
Aug 19, 2009 04:07 PM
Tony H
Jun 14, 2009 10:32 AM
