Clunking
Old Nov 4, 2012 | 12:50 AM
Grayson100944's Avatar
Grayson100944 is on a distinguished road
Default Clunking
I have a 2002 Blazer with an automatic transmission and a few weeks ago my wife accidently turned the key over after it had already been started. It will still start fine but after its been started it clunks for awhile and will also clunk when right before it shifts gears. I thought it may be the gears on the flywheel. Any help before i send it in to the shop to have it fixed?
Old Nov 4, 2012 | 12:59 AM
xgiovannix12's Avatar
sounds like the bolts got damaged on the flywheel that hold either the converter or the flywheel to the motor.
Best to pull the inspection plate and take a look in there.
Check the bolts and the flywheel teeth.
Old Nov 4, 2012 | 09:05 AM
Thats another thing that i've been told. To add on to problems, it loses ALOT of power uphills (im thinking MAF sensor is dirty) and last night the rpm stayed at zero until i parked it and started going again
Old Nov 8, 2012 | 01:20 AM
Well I took it to a local transmission shop and found that the transmission and flywheel had no problems and that it was only the catalytic converter. They cut it off and put a straight pipe on it and charged only $55
Old Nov 8, 2012 | 01:47 AM
easy cheap fix.
Old Nov 8, 2012 | 11:10 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Yeah but how would converter make it clunk?
Old Nov 8, 2012 | 11:26 AM
Smile 2002 blazer
Has no inspection plate to remove,since the housing is fuly enclosed.The only way to inspect would be to remove the starter and turn the engine over and look for damage.
Old Nov 8, 2012 | 10:36 PM
richphotos's Avatar
Wow, a shop cut off the cat and welded on a straight pipe... ?
Old Nov 9, 2012 | 09:35 AM
I was thinking the same thing most shops wont touch that unless they are replacing it.
tankie88
18
Jan 27, 2006 05:33 PM
user 1016
Jan 20, 2006 01:19 PM
Blazin 4x4
Oct 23, 2005 06:11 AM
kwsrv@libcom.com
Sep 7, 2005 05:01 AM
BlazerLS95
Jan 15, 2005 06:47 PM
