code P0155 and P0302
Old May 19, 2013 | 12:25 PM
ezblazer's Avatar
ezblazer is on a distinguished road
Default code P0155 and P0302
Hi everyone! I hope I posted this in the right thread. I'm having trouble with my 2002 Blazer Xtreme .. I got two code and a yellow light on my scanner. I'm trying to get it to pass the smog test. I have only one monitor blinking and its the CAT . I just got the Evap light to clear, but the codes will just not go away. I changed new spark plugs and cables..replaced the co2 sensors and cleaned the MAF. The co2 sensors did clear , but with in a week one of them came back.At this point I don't know what to do. My car registration is about the expired the 2oth of this month. I took pictures of the the scan tool in hopes that you can help me maybe identified the problem.First pictures is from the Freeze Frame that I got and then the live data. Thank you for your help and time.
-Ed
[IMG][/IMG] [IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][IMG][/IMG] Live Data [IMG][/IMG][IMG][IMG][/IMG][/IMG][IMG][/IMG][IMG][/IMG][IMG][/IMG]
Attached Thumbnails code P0155 and P0302-img_20130519_082152.jpg   code P0155 and P0302-img_20130519_082304.jpg   code P0155 and P0302-img_20130519_082206.jpg   code P0155 and P0302-img_20130519_082133.jpg   code P0155 and P0302-img_20130519_082248.jpg
code P0155 and P0302-img_20130519_082403.jpg   code P0155 and P0302-img_20130519_083717.jpg
Old May 19, 2013 | 02:30 PM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
check for vacuum leaks. The map sensor seems to be reading low at idle.
Old May 19, 2013 | 07:07 PM
ezblazer's Avatar
Thank for the info sir!
Old May 19, 2013 | 07:42 PM
i take back that statement, i read the MAP reading wrong. It's still not a bad idea to check for vacuum leaks but it's not reading that off. The p0155 is the heater circuit for o2 sensor bank 2 sensor 1. check the wiring to the o2 sensor and make sure the heater circuit is functioning. If it is verified its geting power and ground then you may have got a defective o2 sensor. P0302 is misfire on cylinder 2, test for good spark, make sure that cylinder is getting fuel, if those check out then the only thing left is to run a compression test
Blazeme
May 18, 2014 12:03 AM
Empire932
Apr 7, 2014 09:45 AM
betron02
Oct 26, 2010 10:31 AM
Queenpin
Mar 5, 2010 03:56 PM
GREZ28
Nov 26, 2009 09:42 AM
