Code P1870
Old Mar 31, 2009 | 02:36 PM
BABs's Avatar
BABs is on a distinguished road
Default Code P1870
Can someone give me a littte insite to what this code means it came on while driving no obvious change in driving, no hard shifting,
the car was in overdrive
i have reset the code and it has not returned yet
96 chevy blazer 4 door 4 wheel 4.3 liter
84,000
the way the code reads is not very helpfull
thanks in advance
Old Mar 31, 2009 | 02:59 PM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
just type ur code in using the search function and youll come up with ur answer or look ur code up in the DTC section.
Old Mar 31, 2009 | 03:00 PM
rriddle3's Avatar
Does this post help any?
Old Mar 31, 2009 | 03:27 PM
BABs's Avatar
i will give it a read thanks
Old Aug 16, 2009 | 04:35 PM
arlonadkinson's Avatar
arlonadkinson is on a distinguished road
If you like go ahead and let someone sell and replace your transmission but here is my suggestion! Check around and see if you can find a minor vacuum leak! This can simply be the big round hose that goes from the fuel injection to the power brake hub! This is normally a push in connector which has about a 1/2 inch hose clamped on it! If there is any kink or the connector is not in correctly a leak will occur and the transmission will shift rough as though you will be thrown out of the vehicle! Try unplugging this connector and plug it back in hard and straight and maybe you will be lucky and fix your problem. If the vacuum is correct your transmission will shift better than you have ever experienced!
max1995
Sep 30, 2010 01:33 PM
knightryderx2
Feb 27, 2010 12:10 PM
robrote
15
Jan 7, 2010 07:37 AM
Nvidia78
Nov 5, 2009 07:25 PM
luthers97blazer
Nov 12, 2008 09:18 PM
