column shifter
Old Aug 8, 2013 | 09:57 AM
panicman57's Avatar
panicman57 is on a distinguished road
Default column shifter
2000 blazer 4.3 column shifter will not go into park can move into park from underneath manually any suggestions ? we are on vacation trans shifts fine, just will not go into park on its own thanks tony
Old Aug 8, 2013 | 11:17 AM
rexmburns's Avatar
Super Moderator
You can try to adjust it underneath the truck by pulling the large retainer clip from the white socket and get some tension and put the clip back in but chances are you are going to need to replace the shifter cable when you get home. To get through vaca I'd just find something to push it into park each time you stop (it can get very hot is why I said find something) and then deal with it at home. Check out the link in my sig for pics and details on adjusting and replacing the cable.
Old Aug 9, 2013 | 09:39 AM
panicman57's Avatar
hey thanks, I figured it was the cable. everything seems to pretty tight underneath tony
matthewp
Apr 4, 2021 09:16 PM
jasedude
Nov 24, 2010 04:03 PM
rbcar1
Dec 13, 2009 10:20 AM
blazerJim1701
Aug 9, 2009 10:32 AM
blazerscooby
Jun 30, 2006 07:24 PM
