converting 4wd to 2wd
Old Apr 3, 2010 | 09:25 PM
giaco's Avatar
giaco is on a distinguished road
Default converting 4wd to 2wd
hi, i am in attempt to build a custom ride out of a 2000 jimmy. My question is if i take off the tranfer case, can i get my drive shaft to go directly into the transmission? if not is it possible?
Old Apr 3, 2010 | 11:02 PM
jacobcnc's Avatar
jacobcnc is on a distinguished road
No, you need a differnt tranny.
Old Apr 4, 2010 | 02:46 PM
Hanr3's Avatar
your better off selling the 4x4 and buying a 2whdr.
You cna use your tranny, however you have to take it ocmplete apart and replace the output shaft with a 2whdr version, plus you need a 2wdr tailhasft housing and you will need to replocat your vss cable, plus get a longer driveshaft, then you have to deal with the front axle. You cant just remove the front driveshaft, you have to remove all of it and replace it with a 2wdr version. that includes your a-arm and all suspension parts.
sell it and buy a 2whdr.
Old Apr 4, 2010 | 05:07 PM
giaco's Avatar
im not using the blazer front axle for my project, can i just take out the front driveshaft and leave the tranfer case? May be wasting my time and should just find another car to mess around with
Old Apr 7, 2010 | 04:25 PM
giaco's Avatar
any replys on just taking out the front driveshaft and letting it spin freely inside the tranfer case?
Old Apr 7, 2010 | 09:58 PM
96Blazernut's Avatar
96Blazernut is an unknown quantity at this point
Like what the other guys have said, you're much better off buying a 2wd Blazer and going from there.
Old Apr 8, 2010 | 08:29 AM
Hanr3's Avatar
That depends, if its a slip fit in teh front diff, NO.
If the driveshaft is bolted to the front diff, than yes.
Same goes for the t-case. slip fit, no; bolt on yes.
Why would you remove the front axle and not remove the t-case OR front axle? What is the point of removing the front driveshaft only?
Old Apr 8, 2010 | 04:46 PM
giaco's Avatar
Im in the process of building a front engine dune buggy. i am taking the rear axle motor and tranny, but i want only a rear wheel drive.
shayne391
Dec 10, 2013 07:13 PM
1996BlazerGute
Jun 27, 2011 09:13 AM
toplessvw
Aug 5, 2009 01:13 PM
Blazerama
Dec 12, 2008 12:22 PM
95_4door
Jul 2, 2008 07:34 PM
