Coolant leak
I have a 96 blazer that is leaking coolant from somewhere in the back of the engine. When I tried burping the coolant system the coolant was leaking under the car from around the transmission. I have replaced the water pump and the t-stat. Any help?
The 4.3 is notorious for the intake leaking. It leaks out around the base on the intake and dribbles down the back of the block.
Tore down and replaced the intake manifold gasket. Had a little trouble getting the distributor timing right but when I did it fired right up. No leak and she runs between 194 and 198/199 when hot. Thanks for the help.
AcerDeucerQ
Dec 3, 2012 06:29 AM
Skeeter Cruz
Mar 4, 2010 07:07 PM
