Coolant Leak in Oil
Old Mar 18, 2011 | 11:07 AM
benthm7's Avatar
benthm7 is on a distinguished road
Default Coolant Leak in Oil
1998 Chevy Blazer LS 4.3; I started up the blazer this morning, drove down the road and it start running hot - temp 210 degree, the oil gage reading at 60 psi. I stop and check the oil dip stick and saw that antifreeze was in the oil. The blazer is running ok for now. At this point I feel it can be the manifold head gasket, because there's a broken bolt, What can I do at this time?
Old Mar 18, 2011 | 02:09 PM
atvwarrior's Avatar
atvwarrior will become famous soon enough
Not much that you can do but change it and sooner the better . These engines are known for the knock in the bottom end .
Old Mar 18, 2011 | 04:34 PM
benthm7's Avatar
Thanks
Old Mar 18, 2011 | 06:26 PM
atvwarrior's Avatar
You should not drive it because its crazy how fast water will make the bearings go bad .
puffy1
Oct 26, 2013 10:16 PM
jdog2pt0
Oct 2, 2012 08:08 PM
portcqb
Mar 27, 2010 12:07 PM
rastaskater
Jan 29, 2008 08:32 AM
TAZ454
Jan 28, 2008 10:11 AM
